FME Desktop 32bit and 64bit on the same machine
  • Dec 14, 2012 7:56 PM UTC
  • 87 views
hpras
Can I have 32bit and 64bit versions of FME Desktop on the same machine.  I need to use some of the datatypes for some projects, but need >4GB memory space for tothers.
Thanks
H
flavio
  • Dec 15, 2012 8:04 AM UTC
Hi
should not be a problem ... I have from 2008 to 2013 all vesions and in addition a 2012 64bit on the same machine ... all work nicely along ...
davideagle
Forum|alt.badge.img+21
  • Dec 16, 2012 2:23 PM UTC
Hi - You can definately do that. You must however be very careful if running FME on the command line, in batch or by using say the WorkspaceRunner as these aproaches will use the default installation which is typically the FME install listed in your "path" environment variable. In these cases rather than running FME as say:
fme c:\\folder\\run.fmw
Fully qualify the path to the engine you'd like to run, like:
c:\\progfiles\\fme2012_sp4_x86\\fme.exe c:\\folder\\run.fmw
This is important in 32 vs 64 bit as some formats are not available on the 64bit platform, see here and sort by Platform:
http://www.safe.com/formats
mhab
Forum|alt.badge.img+10
  • Dec 17, 2012 3:34 PM UTC
Hi
I did some BAT scripting and deliberately called FME 32 when needed and FME 64 in all other cases.
Tricky thing in this is, that on 64-Bit Windows the default CMD window is the 64-Bit version of the command prompt which uses a lot of automatisms to redirect most of things to the 64-Bit environment.
The 64-Bit command prompt is: %windir%\\system32\\cmd.exe
In case you need a 32-Bit CMD you can get it through "%windir%\\Syswow64\\cmd.exe"
Michael
