FME(Data Interop) License is not recoginzed in ArcGIS Pro 2.3
  • Apr 9, 2019 2:16 PM UTC
  • 78 views
I hope someone here can help me out.
I have ArcGIS Pro Advanced license plus Data Interoperability license.
When I was using Pro 2.2, there was no problem. But since I upgraded Pro to 2.3 and Data Interoperability as well, I keep getting FME Desktop License Assistant when I launch Data Interoperability.
Has anyone experienced same issue?
I really need this tool for my UNME work.
Thanks for your attention.
Regards,
Min
bruceharold
Forum|alt.badge.img+20
  • Apr 9, 2019 7:15 PM UTC
Hello Min, this is an Esri support issue, I'll ask someone contact you.
Can you please first check that there are two oemlic files at this location:
C:\\Program Files\\ArcGIS\\Data Interoperability for ArcGIS Pro\\licenses
Regards
Bruce H., Esri.
Hi @bruceharold,
Thanks for reply.
I reinstalled everything again today. Still not letting me use Data Interop.
This is what I found in the directory you mentions.
Any help is appreciated.
Regards,
Min
bruceharold
  • Apr 11, 2019 1:43 PM UTC
Hi @bruceharold,
Thanks for reply.
Regards,
Min
Thanks Min, Harley at GBS in NZ has been sent something to try too, please check with him. Regards.
