Fme citygml to kml while saving its showing error
FME Configuration: No destination coordinate system set
IFMELine was given memory that was NULL or invalid
KML: Error finishing writing dataset
Program Terminating
Best answer by takashi
Hi @balu, the KML writer requires all the features have coordinate system. Check if the features have coordinate system.
  • September 1, 2016
  • September 1, 2016
while reading cityGML file i given Coordinate System
EPSG: 4326
and for writing kml/kmz file Coordinate System
EPSG: 4326
again it showing same error
mark2atsafe
Forum|alt.badge.img+44
  • September 1, 2016
A screenshot of your workspace would be good, to see if you are introducing features from outside the CityGML that won't have a coordinate system.
Also, click Writers > Redirect to Data Inspector and re-run the workspace. Then check the features in the Data Inspector to see if they have a coordinate system. Maybe one or two features are not getting them. The other solution is a CoordinateSystemSetter transformer.
  • September 2, 2016
i am getting cityGML file from SketchUp plugin cityGML in that i am getting cityGML (.gml) format
mark2atsafe
  • September 2, 2016
Yeah, see the coordinate system is set to unknown. But what I really wanted to see was the workspace (Workbench/Canvas/fmw file). If that screenshot was a "Redirect the Data Inspector" then something isn't quite right in there.
itay
Forum|alt.badge.img+17
  • September 2, 2016
any chance the debug logging modus is on?
