FME and Map 3d 2018
  • Feb 26, 2018 6:39 PM UTC
  • 88 views
I'm using Map 3D 2018 64 bit and a trial version of FME 2017.1.0 64 bit.However I cannot get FME to load into the data connector in Map 3D. I have used the integration console to enable FME.I'm trying to translate Mapinfo TAB files into Map 3D including the object data from MApInfo
jneujens
  • Feb 27, 2018 8:34 AM UTC
Are you using a 32-bit windows? If yes, you should try if an older version of FME works. From FME 2017 onwards, the 32-bit FDO is not supported anymore.
See this article for more detailed explanation: https://knowledge.safe.com/articles/59333/autodesk-autocad-map-3d-object-data-translation-fa.html .
jneujens
  • Feb 27, 2018 8:36 AM UTC
https://knowledge.safe.com/articles/505/extending-fme-into-autocad-map.html
