FME 2021.2.6 64-Bit reading/writing Esri ArcSDE 10.8.2: Issue with missing BG Geoprocessing
  • November 15, 2022
  • 26 views
mhab
Forum|alt.badge.img+10
I successfully can read/write Esri Arc SDE (Geodatabase) with FME 2021.2.6 64-Bit and ArcGIS 10.8.2 + Esri BG Geoprocessing installed. So far so good.
If however ArcGIS Server 10.9.1 is also installed in the same enviroment, problems arise and an error message appears, that "BG Geoprocessing is missing" and needs to be installed.
What is the issue here ? How can it be solved ?
It seems only uninstalling ArcGIS Server 10.9.1 solves the problem, but I need ArcGIS Server for other reasons/applications.
B.T.W.: ArcGIS Server 10.9.1 is the corresponding version to ArcGIS 10.8.2, in case you wonder about the version mix ;-)
Thanks for any clue about this
Michael
nielsgerrits
Forum|alt.badge.img+54
Not sure, but I think if you install BG processing after 10.9.1 chronologically it works.
danminneyatsaf
Forum|alt.badge.img+12
I recommend trying what @nielsgerrits​ has mentioned above first.
If that doesn't work, you could try uninstalling Esri BG Geoprocessing, since ArcGIS Server 10.9.1 should provide the 64-bit libraries needed to run the Esri ArcSDE Reader & Writer.
