[FME 2019 - ACAD Reader] Error: The encoded string is not a valid fme-wwjd string
  • Apr 8, 2019 2:33 PM UTC
  • 30 replies
  • 776 views
Show first post
oscard
Forum|alt.badge.img+23
  • Nov 27, 2019 6:59 AM UTC
Hi all. Good news. I am told that this issue is fixed. The fix is in FME 2019.2 as of build 19806. You may have to re-add the reader (I'm not sure) and if for some reason it still causes a problem, then please let us know.
Regards
Mark
When is going to be available? Right now I can download build 19801
mark2atsafe
Forum|alt.badge.img+59
Oops. Yes. You are right. I looked it up and this version will be 2019.2.1 and it should be available next Tuesday (3rd December). That's the plan anyway, and I don't see any issues stopping that from happening.
So, sorry about that, but it will be available very shortly.
pflegpet
Forum|alt.badge.img+8
  • Dec 5, 2019 10:51 AM UTC
Hi Mark,
it seems the error is fixed in 19813 indeed but (at least for me) the Reprojector does not work correctly anymore. I have a workspace based on 19801 where my dwg file was reprojected properly but now its completely wrong. Can you look into this? I can not share the data used but the workspace should reproject from AUT-GK28-5 to WGS 84
pflegpet
  • Dec 5, 2019 11:14 AM UTC
Nevermind - the problem was a shapefile located in the same folder with the same filename as the dwg. I guess the shapefiles prj file was somehow associated with the dwg. When I put the dwg in another folder everything went fine.
jseigneuret
same problem on FeatureReader with Excel file with subdirectory it begin with _
exemple "_name"
