Floor Elevation calculation
  • Feb 4, 2019 2:43 PM UTC
  • 78 views
vini.devgan
Hi, I have building floor plan with floor number (which is like G, M1, M2, M3, F1, ...F19 etc.) and I have height of each floor (like 3.4, 4, 4.5 etc.). We want to show the elevated floors in GIS with as per the exact height from ground (which is height of G+M1+M2+M3+F1+F2 and so on). I have attached a sample file. We have more 10000 buildings and each building has multiple floor so manual calculation of floor elevation is tedious work.
  • Feb 4, 2019 3:07 PM UTC
If the excel records were sorted in the order from low floor to high floor already, you can use the StatisticsCalculator to calculate cumulative sum of their height for each floor.
  • Attributes to Analyze: FLOORHEIGHT
  • Sum Attribute: _sum
Then, take a look at the features outpu via the Cumulative port.
