FileCopy Writer - possible to copy specified files instead of everything in directory?
  • Feb 19, 2020 3:55 PM UTC
  • 5 replies
  • 69 views
Hello everyone,
I am attempting to copy a select number of files from a given directory and came across the FileCopy writer. After experimenting with it, it appears that it is copying all the files specified in the source directory whereas I would like to specify which ones it copies instead. Can anyone confirm this limitation in the writer? And of course, I would be very happy to hear any ideas and workarounds for this. I am considering using PythonCaller to accomplish this but I would like to avoid this if at all possible.
Best answer by ebygomm
It's not a limitation of the writer so it sounds like you've not got it setup quite right. If you have the filecopy_source_dataset set to a folder rather than a file it will copy the whole folder
Forum|alt.badge.img+54
  • Feb 19, 2020 3:57 PM UTC
  • Feb 19, 2020 4:04 PM UTC
In addition to what @ebygomm said, you can also use the "Directory and File Pathnames" reader to get all the filenames in a specific location and then e.g. use the Tester or whatever to select only the files you want to process with the FileCopy writer.
  • Feb 19, 2020 4:55 PM UTC
This is a relief to hear though I can't seem to determine the error(s). I have attached a screenshot of the model. Note, the source directory has over 400 .tif files. I only want the ones I've passed through the testfilter to be written to the destination, but instead all of the .tif files in the source directory (400+) are getting written.
  • Feb 19, 2020 5:07 PM UTC
It looks like the value you are using for filecopy_source_dataset is the entire folder, it needs to include the filename as well
An example
If you want to copy a file called image.tif that's in location C:\\TEMP\\2020 to a new folder called current in C:\\TEMP you need the attributes setting as follows
filecopy_source_dataset: C:\\TEMP\\2020\\image.tif
filecopy_dest_dataset: C:\\TEMP\\current
filecopy_dest_filename: image.tif
  • Feb 19, 2020 6:02 PM UTC
An example
@ebygomm Thank you very much for sharing this. It's working now! The misunderstanding was that I was under the impression that the filecopy_source_dataset only refered to the directory path but as you illustrated it requires the file path.
