FileCopy writer creating 2 destination folders
  • Oct 11, 2021 3:10 AM UTC
  • 159 views
mart
I'm copying PDF files from a source folder to a destination folder. The destination folder is named with today's date (.../outgoing/October-11-2021/).
I used the AttributeCreator to create and format the date attribute called "Date_today" and set filecopy_dest_dataset to "Date_today".
This all works well, the PDF's are copied into the date folder, however, I also get another empty date folder created in the folder that the workbench is in.
Fanout is off. Any ideas how I can stop this extra folder being created?
Folder error
Best answer by danilo_fme
Hi @Martin Olney​
I downloaded your Workspace and re-configurated with my data example. The result was fine when I wante copy files in another folder destination.
I noticed that your folder from Reader is the same location your Copy destination.
Thanks in advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Oct 11, 2021 9:34 AM UTC
Hi @Martin Olney​
Thanks in advance,
Danilo
mart
  • Oct 13, 2021 1:02 AM UTC
Thanks Danilo
I don't know what I did, but somehow the problem has gone.
