File system requirement
  • Apr 21, 2017 2:00 PM UTC
  • 53 views
Hi i am new to FME,we are trying to set up 2 tier architecture.Is that mandatory to have the file system installed on a separate server (please refer the attached image for the instruction i found online) or it can be on the same web/Application server itself? I assume that this file server is a shared directory and can be anywhere on the network.
Thanks,
Mari...
Best answer by david_r
The FME server share can be on the same server as the application server, as long as the folder is accessible from the other servers (shared folder).
  • Apr 21, 2017 2:03 PM UTC
  • May 2, 2017 12:40 AM UTC
Thanks David,I will try on the same server then.
