file Geodatabase to Postgis translation
Hi, I am Sajid Ali studying in HFT Stuttgart. I am facing a problem when I am going to translate Esri File Geodatabase to Postgis. I ahve FME 2013 Version installed and the version of Poistgis is 2.1.2. Please help me out.
fmelizard
Forum|alt.badge.img+19
  • May 21, 2014
What is the problem you are facing?
Have you tried the option to generate a workspace?
  • May 22, 2014
as Itay suggests, try the following in FME:
File -> New -> Generate workspace using wizard...
If you have problems, please post screenshots and/or log file here, together with a description of what you were doing the error occurred.
David
  • May 22, 2014
gazza
  • May 22, 2014
Has PostGIS been enabled on the database?
See 2.5 and 2.6 at http://postgis.refractions.net/documentation/manual-1.5/ch02.html#templatepostgis
Gary
  • May 24, 2014
probably Gary is spot on, you will have to create a PostgreSQL database for PostGIS.
You can also add functions for PostGIS to a PostgreSQL database with executing SQL statements stored in these files.
postgis.sql
postgis_comments.sql
spatial_ref_sys.sql
postgis_upgrade_21_minor.sql
These files are saved in
"C:\\Program Files\\PostgreSQL\\9.3\\share\\contrib\\postgis-2.1"
Note: the directory path and version number may be different according to your installing condition.
Takashi
