Fgdb Annotations to dgn - callouts
  • Nov 29, 2012 4:40 PM UTC
  • 74 views
owen
Hello,
I have annotations stored in a file geodatabase, and can convert the text into dgn labels.
Is there a way of translating the geomerty of annotation callout boxes into lines/polygons? They do not come through automatically...
Owen
fmelizard
Forum|alt.badge.img+22
  • Nov 29, 2012 7:24 PM UTC
If by 'callout boxes' you mean the bounding box of the text, then yes just use the boundingboxreplacer on the text to get the polygons.
owen
  • Nov 30, 2012 9:09 AM UTC
Thanks Itay. Yes I thought you could do it that way - what I need to do though is bring through the geomerty of the callout.
For example if you place an annotation with a callout box, and move the text, you get a speech bubble type leader line to where it was originally placed.
Is there a way of extracting that information and creating the polygon?
fmelizard
  • Nov 30, 2012 1:46 PM UTC
Hi Owen,
I am not sure I understand you, but if you know the location of the object to which the annotation belong, you can try and add a point (2DPointAdder), for example the UR point of the object boundingbox, to the annotation boundingbox polygon.
