FeatureWriter zip shapefile only contains dbf
  • Feb 25, 2019 6:49 PM UTC
  • 8 replies
  • 91 views
Hello,
I am using FME to create several zipped shapefiles (Not SHZ). And when I set my FeatureWriter to "PATH\\@Value(Tbl_Name).zip", the output folder is zipped but only contains the DBF file and nothing else. I am open to other suggestions on how I should be doing this.
Thanks,
Ben
danilo_fme
Forum|alt.badge.img+58
  • Feb 25, 2019 7:08 PM UTC
Hello @blyons81
I suggest you to investigate better your case, you share us the Workspace and Log File.
Thanks,
Danilo
  • Feb 25, 2019 7:30 PM UTC
Sorry about that. It appears that they did not upload earlier. The log file is in the zip folder.
Data_Download_Creator_2.fmw
Data_Download_Creator_2.zip
danilo_fme
  • Feb 25, 2019 7:53 PM UTC
Thanks your informations and sampler of data.
I checked the Log file and there are not geometrys on the data:
And here:
Is there some geometries?
Thanks,
Danilo
  • Feb 25, 2019 8:22 PM UTC
I filtered out areas to be passed along. It still only produces a zip of the dataset with just the dbf file in the folder.
If I have the featurewriter output to SHZ, and then I open that, it contains all of the appropriate files.
Data_Download_Creator_2 (2).zip
danilo_fme
  • Feb 26, 2019 12:22 AM UTC
Please, try to put Inspector on transformers before the transformer FeatureWriter, and check the results on FME Data Inspector - if there are geometry.
danilo_fme
  • Feb 28, 2019 10:46 PM UTC
Hello, Did you do this test with Inspectors?
danilo_fme
  • Mar 6, 2019 1:46 PM UTC
I ended up reworking the entirety of the workspace.
