FeatureWriter using MITAB outputs incorrect CRS when incoming features are set to "LL-GDA2020_FME"
  • Aug 7, 2020 4:17 AM UTC
  • 34 views
jstanger
Using FME version 2019.2.3.1 it appears that if the MITAB writer format is selected within a FeatureWriter that non-standard CRS's default to an arbitrary "LL" CRS based on WGS84.
When tested not using the FeatureWriter this doesn't appear to occur. The FeatureWriter does not allow setting of output Coord. System from an attribute therefore I am required to rely on "Same as source". I do have a MITAB workspace resource but again I cannot set the Coord. System as a Parameter and only as an Attribute in my use case.
Is this a limitation on the FeatureWriter or on the MITAB writer and MapInfo format itself when it comes to very new Projections?
daveatsafe
Forum|alt.badge.img+24
  • Aug 7, 2020 9:19 PM UTC
Hi @jstanger​ ,
Would you mind sharing an example workspace with us? I tried to reproduce the problem with a very simple workspace, but was able to write out an LL-GDA2020_FME feature to MITAB that read correctly in Mapinfo 2019.
As a workaround, in the MITAB writer parameters, you can set the Mapinfo coordinate system statement to be taken from an attribute. This will override the coordinate system on the feature itself.
