featurewriter parameters sql server writer bulk insert and other parameters missing
  • Dec 8, 2016 10:06 PM UTC
  • 120 views
Feature writer transformer does not expose all writer parameters. I'm passing fme_db_operator to it with the value of update, but it tries to insert. In the past I have been better able to troubleshoot with bulk insert off (it's on by default), but I can't find it to turn it off. Is that because it's not exposed?
steveatsafe
Forum|alt.badge.img+16
@deanrother Yes this was something that was not part of the FME 2016 release. However we've already added this functionality to FME 2017 beta. If you'd like to kick the tires check out www.safe.com/beta for FME 2017 beta downloads.
steveatsafe
The ability to turn off bulk inserts has been added to FME 2017. Beta's are available now.
Using navigator, it is found in the parameters section of the writer.
