Featurewriter Excel error "Named range from /xl/workbook.xml part" only with 2024.1.2.0
  • Oct 1, 2024 6:51 AM UTC
  • 0 replies
  • 83 views
topotoma
Forum|alt.badge.img+4
Hello,
When using Featurewriter with a template excel file, i encounter en error when trying to open the written excel file which indicates a problem with the Named range "Named range from /xl/workbook.xml part".
This happens only since updating to 2024.1.2.0, if I use the same workspace with 2022 version it’s fine.
Has this happened to someone else ? is there a workaround ?
I’ve tried a lot of things but couldn’t find the issue so for now we run this workspace with 2022.
Thanks for your help.
