FeatureWriter error
  • Jun 20, 2017 4:06 PM UTC
  • 103 views
Hi I have used a FeatureWriter to write to an SDE feature class. While this seems to work, I am still getting an error in the log file.
Any ideas?
Total Features Written                                                    9669
The below feature caused the translation to be terminated
Storing feature(s) to FME feature store file `C:\FME\BatchProcesses\FMEDailyProcesses\log\pipes_logFile_log.ffs'
Feature Type: `Tester_PASSED'
Attribute(string)                 : `_dataset' has value `<Unused>'
Attribute(32 bit unsigned integer): `_feature_type{0}.count' has value `9669'
Attribute(string)                 : `_feature_type{0}.name' has value `wgis.pipes'
Attribute(encoded: fme-system)    : `_num_features_read' has value `9669'
Attribute(32 bit unsigned integer): `_total_features_written' has value `9669'
Attribute(string)                 : `fme_geometry' has value `fme_undefined'
Attribute(string)                 : `fme_type' has value `fme_no_geom'
Geometry Type: Unknown (0)
Terminator(TestFactory): Terminator: Termination Message: 'Translation Terminated'
Abnormal termination of the Geodatabase reader
Closing the Geodatabase reader
Feature output statistics for `FFS' writer using keyword `W_1':
                               Features Written
Total Features Written                                                       0
Stored 1 feature(s) to FME feature store file `C:\FME\BatchProcesses\FMEDailyProcesses\log\pipes_logFile_log.ffs'
FME Session Duration: 26.8 seconds. (CPU: 13.5s user, 0.8s system)
END - ProcessID: 308, peak process memory usage: 155212 kB, current process memory usage: 139816 kB
FME_END_PYTHON: evaluating python script from string...
erik_jan
Forum|alt.badge.img+26
  • Jun 20, 2017 5:30 PM UTC
Do you have the Rejected Feature handling set to Terminate the workflow?
mark2atsafe
Forum|alt.badge.img+59
Yes, that could well be the issue. It can also be dealt with by adding an Inpsector or Logger transformer to the Rejected port, or by using the Rejected Feature parameter in the Parameters Window (See workspace parameters)
Erik's suggestion will work for all new workspaces, but this parameter will work for the current workspace.
