Features inside Subfolders KML
  • Jul 28, 2016 5:54 PM UTC
  • 6 replies
  • 269 views
danilo_fme
Forum|alt.badge.img+58
Hello all,
I have a workspace that generate a KML file with Folder and Subfolder. The problem is doenst write nothing points inside the Subfolder.
Thanks all :)
Best answer by jdh
The kml_parent needs to reference the kml_id of the parent feature, not the name. I see that the subfoldersB have a kml_id so the features are finding them, but I can't tell if you subfolderA has one.
Also, you only need to create the folder structure once, not 211 times. See kmlfolders.fmw as an example.
jdh
Forum|alt.badge.img+41
  • Jul 28, 2016 5:56 PM UTC
Is the kml_parent set on the source features?
danilo_fme
  • Jul 28, 2016 6:14 PM UTC
Hello @jdh,
Yes:
workspace-know.fmwt
jdh
  • Jul 28, 2016 6:32 PM UTC
Your folders Ativo and Inativo have a kml_parent, but I don't see you features being assigned a kml_parent of Ativo|Inativo.
danilo_fme
  • Jul 28, 2016 7:12 PM UTC
hello again @jdh thanks your help. I tried the configuration kml_parent to Ativo and Inativo, and the features are writted. :)
Now the Folder Base Ativa doesnt created.:
jdh
  • Jul 28, 2016 7:29 PM UTC
danilo_fme
  • Jul 28, 2016 8:36 PM UTC
Thanks @jdh !!! Its works now!!! :)
