Feature Joiner using Between operator
  • December 24, 2024
  • 41 views
stephaniemcphie
Is there a way to join two tables using the between operator (SQL). I know I can use SQLCreator but I would like to do this join directly in workbench.
sql example:
TABLE1.*,
TABLE2.*
FROM TABLE1
LEFT JOIN TABLE2
 ON TABLE1.NAME = TABLE2.NAME AND TABLE1.DATE BETWEEN TABLE2.FROM AND TABLE2.TO
evieatsafe
  • December 27, 2024
Hi ​@stephaniemcphie thanks for your question. I’m not sure you can do the between operation in the FeatureJoiner. I think you might have to use a Tester or TestFilter to select the range after you have joined them with the FeatureJoiner. If you want to do this all in one step then the SQL transformers would be better for this.
let me know if this helps or if you have further questions!
hkingsbury
Forum|alt.badge.img+55
  • January 5, 2025
For your join clause you can rewrite it to:
    AND TABLE1.DATE >= TABLE2.FROM
    AND TABLE1.DATE <= TABLE2.TO
ctredinnick
Forum|alt.badge.img+19
  • January 6, 2025
Since you don’t want to do it in SQL with an InlineQuerier and do it entirely in workbench transformers, your best bet is the custom transformer FeatureRangeMerger.
