Fatal error after termination. Why is that?
  • Jan 5, 2018 4:12 PM UTC
  • 132 views
Here's the output:
Terminator(TestFactory): Terminator: Termination Message: 'PARCEL_LIMIT_EXCEEDED'
Bridge failed to output feature on tag `PYOUTPUT'
f_218(PythonFactory): PythonFactory failed to process feature
Feature output statistics for `FFS' writer using keyword `W_1':
Features Written
Total Features Written 0
Successfully closed POSTGRES database reader
... Last line repeated 5 times ...
Closing the Geodatabase reader
... Last line repeated 2 times ...
Stored 1 feature(s) to FME feature store file `C:\\test_log.ffs'
FME Session Duration: 33.0 seconds. (CPU: 4.5s user, 12.1s system)
END - ProcessID: 21364, peak process memory usage: 635072 kB, current process memory usage: 619632 kB
FME_END_PYTHON: evaluating python script from string...
FME_END_PYTHON: python script execution complete.
Program Terminating
Translation FAILED.
Warning: not all FMESessions that were created were destroyed before shutdown. This may cause instability
  • Jan 5, 2018 4:14 PM UTC
Looks like there's a Terminator transformer somewhere in your workspace that got triggered.
Hi David, actually i have a tester and if even it fails one feature then i want to trigger the terminator. Anf that's what i am doing. But I don't want this fatal error with that.
  • Jan 7, 2018 6:10 AM UTC
The Terminator stops the translation with an error when it received a feature. It's the intentional behavior of the transformer and you cannot change that.
If you don't want to stop the translation even if the Tester routes a feature to the Failed port, consider replacing the Terminator with a Logger to log the failed feature without stopping the translation.
  • Jan 8, 2018 2:46 PM UTC
Can you please brief your workflow? Its looks like python execution issue.
