Extracting WKB geometry from JDBC Redshift table
  • Jun 4, 2026 2:40 PM UTC
  • 45 views
lorinda
Hi all,
I have a table in Redshift that is JDBC (not the spatial version of Redshift); it has a column that is in WKB.  I need to extract this and create points in Lat Long.  I’ve tried the geometry extractor but getting nowhere fast.  Have also tried sql executer to use the ST_geometry to get the coords, nowhere again.  When I tried to use the Redshift connections, the username/pwd and related connection data did not connect.  It is only with JDBC that I can create the connection.
Anyone had any experience with this?
Thanks,
Lorinda
Forum|alt.badge.img+54
  • Jun 4, 2026 3:07 PM UTC
If you have a column that is WKB you should be able to convert that to a geom with the GeometryReplacer
lorinda
  • Jun 4, 2026 4:12 PM UTC
Was able to do that and then reproject to our projection.  Now just working on getting it to write to my SDE, it’s being finicky.  Had to use Hex Encoded OGC Well Known Binary rather than straight WKB.
