extracting data from a JSON file
  • Dec 11, 2020 3:05 PM UTC
  • 127 views
simonhume
Forum|alt.badge.img+7
Hi
I've been given a JSON file containing registrations for 5 properties. We are looking to use other datasets with a single field in the json file to identify the location of the property.
I am looking to produce a csv file initially with each record on a separate line
Can someone comfirm if the following is correct or not please.
Open the JSON file using the JSONFeature Reader
Connected a JSONFragmenter, using one of the fields as the JSON Query. I've attached a screenshot of the settings for the JSONFragmenter.
When i run the workspace and view the result in the Inspector,i can see the records listed in the right hand pane, but writing out a csv file with each record on a separate line doesn't work.
thanks for any assistance
Forum|alt.badge.img+54
  • Dec 11, 2020 3:57 PM UTC
It's hard to advise without seeing the json
simonhume
  • Dec 14, 2020 8:42 AM UTC
Hi
file is attached
  • Dec 14, 2020 9:07 AM UTC
It looks like you just need to explode the list applications{} after reading with the FeatureReader
Capture
