Extracting coordinate system from FILE GDB Feature Dataset when feature class is empty.
  • Oct 13, 2017 3:53 PM UTC
  • 186 views
dfresh
Say I have a FILE GDB called Fruit with the following feature datasets (Oranges).
say there are not feature rows inside Peel or Slices feature classes. how can I extract the coordinate system
Fruit
  • Oranges (feature dataset)
    • peel (feature class)
    • slices (feature class)
In arcCatalog I can easily right click the feature dataset and go to the XY coordinate system tab to see this.
methods I have tried in FME
  • TCPL start up script - (here I extract domains and geometry type, but no COORD systems)
  • populating a single row in FME, than reading trying coordinate extractor
  • python caller - this will not work if feature dataset is empty
Thanks,
Doug
Best answer by daveatsafe
Hi @dfresh,
If you use the Esri Geodatabase (ArcObjects) reader, you have the option to set the Feature Read Mode to Metadata. This will allow the reader to return a metadata feature for each feature class.
The metadata feature geometry will be the bounds of the feature class, in the feature class coordinate system, so you can use a CoordinateSystemExtractor to get the coordinate system name in an attribute.
If you want the Esri WKT for this coordinate system, you can use the CoordinateSystemDescriptionConverter transformer to convert the attribute containing the FME coordinate system name to Esri WKT.
danilo_fme
Forum|alt.badge.img+58
  • Oct 13, 2017 4:07 PM UTC
Hi @dfresh,
Did you try to use a PythonCaller and a scrpit to get the coordinatesystem:
import fme
import fmeobjects
def _sistema_coord(feature):
    csMgr = fmeobjects.FMECoordSysManager() # call coord system
    cs = feature.getCoordSys()  #get the coord system of features
    if cs != None and cs != '':
        params = csMgr.getCoordSysParms(cs)
        if 'EPSG' in params:
            loc = params.index('EPSG') + 1
            feature.setAttribute('EPSG',params[loc])
But i believe to need to have a feature beforr this transformer.
Thanks,
Danilo
dfresh
  • Oct 13, 2017 4:13 PM UTC
Hi @dfresh,
import fme
import fmeobjects
Thanks,
Danilo
yes you do need a feature, so this one wont solve it.
daveatsafe
Forum|alt.badge.img+24
  • Oct 13, 2017 8:14 PM UTC
Hi @dfresh,
dfresh
  • Oct 17, 2017 10:00 PM UTC
Hi @dfresh,
Thanks @DaveAtSafe
you solved it, I completely forgot about the metadata feature read mode. this is exactly what I need. thanks!!
