Extract text strings into different attributes
  • Jan 6, 2017 12:17 AM UTC
  • 7 replies
  • 1182 views
Hi FME experts,
I have a number of text files that looks like this (attached). I would like to extract the numbers and store them into different attributes to process them further.
A 468832.92042276752
B 7175381.1634021383
C 2829
D 388
What is the best way to approach this?
So far, I tried unsuccessfully using attributesplitter, substringextractor
I tried wresting with regex
For instance, the following expression returns
everything in between the first ( and the last , but how can I extract each string separately?
Many thanks in advance.
!table !version 300 !charset WindowsLatin1
Definition Table File "a2.jpg" Type "RASTER" (468832.92042276752,7175381.1634021383) (2829,388) Label "Pt 1", (468991.81894034828,7175225.3923977558) (4127,1684) Label "Pt 2", (468917.96947360213,7175142.166946603) (3520,2370) Label "Pt 3", (468878.98707272188,7175056.807626294) (3195,3063) Label "Pt 4", (468691.66407155019,7175209.742227288) (1660,1784) Label "Pt 5", (468758.97137093107,7175297.6046385625) (2221,1071) Label "Pt 6" CoordSys Earth Projection 8, 116, "m", 153, 0, 0.9996, 500000, 10000000 Units "m"
Best answer by takashi
Hi @thiru, I think the StringSearcher with this regular expression can extract the number parts from each text line.
The workflow looks like this.
  • Jan 6, 2017 1:29 AM UTC
  • Jan 6, 2017 1:55 AM UTC
thanks @takashi for your suggestion. that worked perfectly.
  • Jan 6, 2017 2:23 AM UTC
Hi @takashi, how do I read the second line into E, F, G, H and I need to do this until I exhausted all the number strings.
Should I read one line of text from the text file and use your suggestion?
  • Jan 6, 2017 2:52 AM UTC
This workflow does the trick. The NumToAlphaConverter custom transformer is published in the FME Hub.
See also the attached demo workspace (FME 2016.1.3): regex-example-2.fmwt
[Edit] Updated the workspace so that the result will be written into an Excel spreadsheet: regex-example-3.fmwt
  • Nov 21, 2018 10:33 AM UTC
Hello, I have a similar case and have a problem finding the right regular expression. I get from various programs a coordinate list, which differs slightly in formatting.
Here are two examples of text lines from different files:
list.txt
From these lines I have to read X and Y, which are additionally interrupted with one or more spaces.
Can someone please give me a hint?
  • Nov 21, 2018 1:22 PM UTC
list.txt
Hi @rt_gis, if the value always has decimal places, this expression matches that.
\d+\s+\d+\.\d+
For example, the StringSearcher below populates the two values from a text line into a list attribute "_list{}.match".
  • Nov 21, 2018 1:49 PM UTC
\d+\s+\d+\.\d+
Many Thanks. You helped me again.
