Extract JPG files through Fulcrum API
  • Apr 8, 2024 1:37 PM UTC
  • 202 views
galigis
Forum|alt.badge.img+22
Hi All,
I’m working on a workflow to extract JPG files using the existing Fulcrum API. I have been able to install the Fulcrum web connector from the FME Hub and make the relevant connection to my organisations using a Token. All good.
The problem is am not be able to view the URL photos in my browser as shows ‘This page isn’t working’. Below the workflow to extract the photos:
  • Creator
  • HTTPCaller
  • JSONFragmenter
  • AttributeFileWriter
Below a screenshot of some of the URLs in the JSONFragmenter:
Does anyone know why I am getting the This page isn’t working error?
Best answer by nielsgerrits
I think you need to use a second HTTPCaller instead of the AttributeFileWriter to get the photo. You can write it directly from the HTTPCaller to disk.
nielsgerrits
Forum|alt.badge.img+67
galigis
  • Apr 8, 2024 2:59 PM UTC
Classy. It worked! I had to slightly modify the expression for the second HTTP caller based on the API query expression and add /large.jpg
Below an screenshot of the workflow for completeness.
danilo_fme
Forum|alt.badge.img+58
  • Apr 8, 2024 4:13 PM UTC
Great solution!
