Expose Feature Attributes from KM
marta.podsiad
Forum|alt.badge.img+9
I have error while running the workbench from How to Expose Feature Attributes from KML Tags or HTML Tables – FME Support Center
It failes at point Method 2: XML> 2. Fragment XML
Any idea why it does not work. I have not changed any of the settings in that workbench
Best answer by marta.podsiad
It looks like there is a bug in FME 2024.0. I have run the same workbench with older version and all workded as expected
danilo_fme
Forum|alt.badge.img+45
  • April 17, 2025
Hi ​@marta.podsiad
Please, could you share your data?
marta.podsiad
  • April 18, 2025
Hi, I am running the workbench that is saved under this link How to Expose Feature Attributes from KML Tags or HTML Tables – FME Support Center
nielsgerrits
Forum|alt.badge.img+54
Can’t reproduce your error. I downloaded and ran the workspace as is without any issues in FME 2021, 2023 and 2025.
marta.podsiad
  • April 18, 2025
nielsgerrits
2024.2 gives me no issues. I see you use 2024.0. Not sure this is the issue, but in general I would not advise to use .0 versions for production work.
marta.podsiad
  • April 18, 2025
what should the text look like in HMLToHTML Converter?
marta.podsiad
  • April 23, 2025
