Export GeoDB to Excel
  • May 30, 2018 6:08 AM UTC
  • 9 replies
  • 145 views
boubcher
Forum|alt.badge.img+11
Hello
I am Looking to export the Geodatabase schema ( manay tables) without the data to an excel sheet
column 1: table name
Column2: attribute name
Column 3: attribute type
Column 4:width
Best answer by takashi
Hi @boubcher, you can use the Schema (Any Format) reader to read only the schema features. Each schema feature has a list attribute called "attribute{}" which contains the information on the schema of a single feature type.
  • fme_feature_type_name: feature type (table) name
  • attribute{}.name: attribute name
  • attribute{}.native_data_type: data type name in the source format
  • attribute{}.fme_data_type: FME generic data type name
Data type name contains width if necessary. e.g. fme_char(64).
Alternatively, you can also use the FeatureReader to read only schema features, if you set "Schema Features" to the Features To Read parameter.
  • May 30, 2018 6:18 AM UTC
boubcher
  • May 30, 2018 6:24 AM UTC
This is the sample Data we are looking to export to Excel
export-to-excel.zip
boubcher
  • May 30, 2018 6:39 AM UTC
@takashi
the geoDb has no data in it, I used creator, but I am getting nothing schema-export-to-excel.png
  • May 30, 2018 6:41 AM UTC
@takashi
Schema features will be output via the <Schema> port.
boubcher
  • May 30, 2018 7:32 AM UTC
@takashi
I am not getting the mentioned attribute list on the output , is there any specific configuration ?schema-export-to-excel-output.png
  • May 30, 2018 7:37 AM UTC
@takashi
Generally list attributes won't appear on the Table View in FME Data Inspector. To inspect detailed contents of the feature including list attributes, see the Feature Information window after selecting a feature on the Table View.
boubcher
  • May 30, 2018 10:43 AM UTC
@takashi
Sorry I am still not getting all the attributes list there
please see attached the WS and the output
sechema-extraction.fmwattribute-exposer.xlsx
  • May 30, 2018 10:51 AM UTC
@takashi
Have a look at the ListExploder transformer.
You will have to learn more about List. Read the documentation: About List Attributes
boubcher
  • May 30, 2018 12:32 PM UTC
@takashi
It work finally , after using the attribute exploder
