Expanding ranges and adding records to a DBF file
  • Jun 30, 2014 3:56 PM UTC
  • 75 views
Hi I'am trying to create an expanded set of numbers and therefore new records, based on a range of numbers. EG attribute START has a value of 1 and attribute END has value of 5. The result I am looking for 5 separate records where START is 1, 2, 3, 4, 5 & END is 0
gio
Forum|alt.badge.img+15
  • Jul 1, 2014 12:22 PM UTC
Creator (Null geometry) and then a cloner, number of copies set to a user parameter called range and copy number attribute to "START". Then an a attributecreator set to "END".
Is that what u meant?
gio
  • Jul 1, 2014 12:23 PM UTC
..erhmm In creator also START=START +1..(as copier starts at 0)
