ExcelStyler - Conditional background formatting based on value of another cell
  • Apr 11, 2019 1:32 PM UTC
  • 8 replies
  • 255 views
tsirkuse
Forum|alt.badge.img+4
I would like to color the cells of my first column ID_WS based on the text value contained in a cell UPDATE_STATUS which basically contains the fme_db_operation value.
I tried to apply the styling with ExcellFormater but it doesn't seem to be working in the output.
What am I doing wrong here ? Thank you !
Best answer by ebygomm
The excel styer should be creating an attribute called ID_WS.formatting, this needs to be written out as an attribute for the styling to work. I don't see it included on your writer in the image you posted.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @tsirkuse, what version of FME are you using? In 2019, when you are configuring the Parameter Condition Definition, you can pick the colour using the ... button. This will give you the right values to represent your chosen colour. In my test this works as expected.
Hope this helps.
Xiaomeng
tsirkuse
  • Apr 16, 2019 9:39 AM UTC
Hope this helps.
Xiaomeng
Hello,
I am using 2018.1 and I have been using the button to select the color, yet I don't get any color formatting on my output excell sheet.
Any ideas ?
Thanks
Forum|alt.badge.img+54
  • Apr 16, 2019 9:47 AM UTC
tsirkuse
  • Apr 16, 2019 11:21 AM UTC
Hello,
The attribute is written out in the styler but not in the writter. This matches an example I found on the safe website
I tried connecting the ID_WS.formatting to a format attribute in the writer but this creates an error in Excel on opening the document.
Example :
  • Apr 16, 2019 11:27 AM UTC
Hello,
Example :
The attribute on the writer needs to be called ID_WS.formatting, it is set as a user attribute not a format attribute.
An example which creates 10 features, which are then styled depending on whether they are odd or even. Written out to one sheet with the ID.formatting attribute and the other sheet without
excel_apply_format.fmw
tsirkuse
  • Apr 16, 2019 12:03 PM UTC
Hello,
The formatter seems to work only when applying the formatting to the same cell the value is used conditional for.
Whenever I try to style ID_WS based on another column, it fails.
Thank you
tsirkuse
  • Apr 16, 2019 12:04 PM UTC
Hope this helps.
Xiaomeng
@xiaomengatsafe the styler seems to work only when basing formatting on values of the same cell/attribute/feature. If I am trying to style my first column based on a value in another column, it doesn't work.
  • Apr 16, 2019 12:09 PM UTC
Hello,
Thank you
I don't see the same behaviour. If i change the excelstyler to style a second_column based on the ID column it works
