Excel Writer puts formulas as literal text strings instead of evaluating them
  • Jul 13, 2026 6:53 AM UTC
  • 76 views
kevink
Forum|alt.badge.img+3
Hi all,
I am trying to write a dynamic Excel formula (=SUBTOTAL(103, A2)) to an Excel sheet using FME Form, so that it evaluates automatically when a user opens the spreadsheet. However, FME keeps writing the formula as a literal text string (showing =SUBTOTAL(103, A2) in the cell) instead of calculating the actual formula.
Here is what I have configured so far based on the documentation:
  1. AttributeManager:
    • Created an attribute named ZICHTBAAR.formula
    • Value set to: =SUBTOTAL(103; A2) (or with a comma depending on locale)
    • I also exposed the base attribute ZICHTBAAR without the extension.
  2. Excel Writer Feature Type (User Attributes):
    • The column ZICHTBAAR is present.
    • I tried setting the Data Type to both string and auto.
The issue: When running the workspace and opening the output file in Excel, the cells still show the raw formula text. It only evaluates to 1 or 0 if I manually double-click the cell and press Enter, or force a hard recalculation.
What am I missing to make the Excel Writer natively flag this column as a live, evaluable formula from the get-go?
max_h
Forum|alt.badge.img+39
  • Jul 14, 2026 7:14 AM UTC
I am using FME 2026.1 and works fine for me with default settings:
My suggestion would be to check your excel formulas options, maybe you have show formulas activated or something like that as your fme script seems correct.
Forum|alt.badge.img+63
​@max_h just beat me to the answer, but yeah, it works for me too.
My AttributeCreator:
And the output feature type:
Note I am not writing a value to the zichtbaar attribute, just to zichtbaar.formula
kevink
  • Jul 15, 2026 6:44 AM UTC
Im going to try it, thanks
