Excel read write works in workbench but fails with strange error when published
I have an input excel file that is the source some HTTP calls are made to fill in columns in the spreadsheet using a template file and a defined output file overwritten. It runs in workbench but fails when published with an error that I can't locate the function or () it is complaining about. I have searched the error log for the text in the error and can't find a parameter with out a ()?
Function `XLSXW_OUT_TEMPLATEFILE_XLSXW_1' must be called with any parameters enclosed in ( ), even if there are none
Some details are:
FME Server 2016.0.1.1 - Build 16177 - win32
Copyright (c) 1994 - 2016, Safe Software Inc.
Direct Url Example
http://CODC1ITS8SGS984:8080/fmedatadownload/fmeservices/rlc_routecm2rpt.fmw?ExcelAnswerrtcm2rpt=G%3A%5CRFWorkspace%5Crlcupload%5CrlcUpload1Answer.xlsx&ExcelInputrtcm2rpt=G%3A%5CRFWorkspace%5Crlclrs%5CrlcUpload1.xlsx&RLCExcelTemplateFile=G%3A%5CRFWorkspace%5CrlcTemplateFile%5CrlcUpload1Template.xlsx&opt_showresult=false&opt_servicemode=async&opt_requesteremail=xxxxxxx
Published Parameters
Description
Parameter Name
Type
Current Value
Default Value
Options
Destination Microsoft Excel File:
ExcelAnswerrtcm2rpt
FILENAME
G:\\RFWorkspace\\rlcupload\\rlcUpload1Answer.xlsx
Source Microsoft Excel File(s):
ExcelInputrtcm2rpt
MULTIFILE
G:\\RFWorkspace\\rlclrs\\rlcUpload1.xlsx
Template File:
FILENAME_MUSTEXIST
G:\\RFWorkspace\\rlcTemplateFile\\rlcUpload1Template.xlsx
Hi @fish1ric,
In FME Server file paths should be referenced using a UNC path rather than a mapped drive (https://knowledge.safe.com/articles/376/workspace-fails-using-fme-server-data-in-mapped-dr.html). Please could you try referencing the file paths using a UNC path ensuring the account running the FME Server Services has permissions to read/write to these locations. I'm not sure that is the issue here but it is good to be aware of.
Users have encountered similar errors when there is a problem with the published parameter configuration, can you confirm if you right click >Edit Definition on the Template file parameter that none of the parameters are red?
Also is your FME Desktop the same build number as FME Server? I would like to try and repro the error but have not yet been able to - if you could also share your workspace and a sample dataset this would be helpful here.
nielsgerrits
Forum|alt.badge.img+54
Not sure if this is your issue, but I had some problems when writing to excel which were related to technical fme attributes.
In my case I used an AttributeKeeper to remove fme_db_operation from a feature which was send to both a database and excel. The issue was that techical fme attributes are getting unexposed, not removed, by an AttributeKeeper. So the excelwriter wanted to react on the fme_db_operation, saying it needed to delete a row, but had no source file.
These kind of issues are always hard to track down, so you might want to check this out.
