ESRI SDE (SDE3) Annotation feature to AutoCAD
  • Aug 16, 2013 12:56 PM UTC
  • 75 views
Hi All,
While importing ESRI SDE (SDE3) Annotation feature to AutoCAD drawing with object data.
We are getting Annotation features as polygons.
Cloud you please provide suitable solution, so we can export attribute data of SDE to AutoCAD annotations as TEXT/MTEXT instead of polygons.
regards
Govardhan
fmelizard
Forum|alt.badge.img+22
  • Aug 16, 2013 1:26 PM UTC
The text adder will transform any features in to text.
Itay
srg
Forum|alt.badge.img+10
  • Aug 17, 2013 4:57 AM UTC
Govardhan,
Are you using some labeling functionality in AutoCAD using the Object Data attribute?
Do you need the annotation text asobject data in AutoCAD or as text elements?
If you need to write Object data, I think you need to use Autodesk AutoCAD Map 3D Object Data Writer.
Cheers
Happy FME-ing :-)
SRG
  • Aug 19, 2013 12:35 PM UTC
Hi All,
Thanks for the suggestion, we are able to convert ESRI (SDE) attribute to AutoCAD text by using TextAdder transformer.
-Govardhan
