ESRI PORTAL ITEM Fanout
  • Sep 11, 2019 5:38 PM UTC
  • 0 replies
  • 30 views
Could anybody tell me if this possible with FME please? I'm new to using ESRI Portal Items and FME .
I have a Feature service on Portal published via arcgis server from an enterprise geodatabase in Oracle, I wish to create views of this data in Portal by Fanout on an attribute value. e.g a Feature service of Polygons with and attribute of Sheet_no, I'd like to create a Portal item for a definition query on the master layer for each group of unique Sheet_no values, giving these items a new name based on the original item name + the Sheet_no... The data cannot be duplicated and the view must reference the original service and data source.
This apparently can be done using the Portal Python API .... but I'd like to see if it can be done in FME.
Any pointers are appreciated
Regards
Paulg
