Esri ArcGIS Image Server Reader - 64bit or alternatives
  • Apr 4, 2023 9:16 AM UTC
  • 206 views
jacklonsdale
Forum|alt.badge.img+5
Hi all,
Trying to read in UK LiDAR composite data via a FeatureReader and spatial filtering - https://www.data.gov.uk/dataset/01b3ee39-da3f-47b6-83da-dc98e73a461f/lidar-composite-dtm-2022-1m
I see there is an Esri ArcGIS Image Server Reader (https://docs.safe.com/fme/2021.1/html/FME_Desktop_Documentation/FME_ReadersWriters/arcgis_image_server/arcgis_image_server.htm) which should help facilitate this - but it is not available on 64 bit. Is there any update as to when this may be supported or a current workaround for 64bit?
Thanks!
Jack
birgit
Forum|alt.badge.img+25
  • Apr 4, 2023 3:03 PM UTC
The reader itself also only supports up to version 10.0 of Image Server while the Service you want to read is already version 10.81. It kind of feels like this reader is deprecated which would be a shame because ESRI still sells new Imagery Servers. You might be able to query the service using http callers and the ArcGIS REST API for Image Server : https://developers.arcgis.com/rest/services-reference/enterprise/image-service.htm
