ESRI ArcGis 10.4.1 and FME
  • Aug 22, 2016 2:23 PM UTC
  • 5 replies
  • 48 views
erik_jan
Forum|alt.badge.img+26
A customer of SBS has upgraded the ESRI client to 10.4.1
FME 2014 (they use that version) is not supporting this ESRI client.
Can anybody inform me about the minimum required FME version compatible with ARCGis 10.4.1?
Thanks.
mhab
Forum|alt.badge.img+10
  • Aug 22, 2016 3:07 PM UTC
erik_jan
  • Aug 22, 2016 4:27 PM UTC
Thanks @mhab,
I had seen that article, but it is not mentioning 10.4.1
And I understood form my customer that a change has been made from 10.4 to 10.4.1
richardatsafe
Forum|alt.badge.img+11
Hi Erik Jan,
For ArcGIS 10.4.1 you will need FME 2016.0.1 and higher.
mhab
  • Aug 24, 2016 8:56 AM UTC
Hi Erik Jan,
What is the reason you need 2016.0.1 or higher ?
I didn't find info about ArcGIS 10.4.1 in 2016.1 what's new listing, except for a fix on connection file picker, so I wonder about the background ...
bruceharold
Forum|alt.badge.img+20
  • Sep 27, 2016 5:44 PM UTC
The FME 2016.0.1.2 engine went into Data Interoperability 10.4.1.
