Error "Unable to open log file"
  • Sep 17, 2019 10:55 AM UTC
  • 1341 views
cheffing
Participant
I often get this error, while the Workspace-Runner was started with new parameters.
Reducing the log-level did not help
Any idea how to fix this? I found no comparable community-Item ..
I am calling a Workspace-Runner within the project. The workspace is called thousends of times. The calling workspace and the called one work each into their own log-Files. In this example 954 of 1461 calls crashed. In the logfile of the called wsp there are now errors mentionend.
Many workspace-calls crash because the newly initialized workspace can't access the logfile because the last call has not yet closed it.
This is the error description:
I would like to use the option with concurrent processes, but it increases the error rate.
The called wsp has one logger configured like this:
What else is needed to give you an idea of the problem?
Looking forward to a solutiion,
Christoph
gio
Forum|alt.badge.img+15
  • Sep 17, 2019 11:54 AM UTC
@cheffing
Do you have more information?
Maybe the workbecnh or so?
erik_jan
Forum|alt.badge.img+26
  • Sep 17, 2019 3:47 PM UTC
Can you check if the folder for the log file exists?
That is the only time I have seen this error (trying to write a log file in a non existing folder).
cheffing
Participant
  • Participant
  • Sep 17, 2019 8:51 PM UTC
Thanks for your support, Eric-Jan!
The folder and the file definitly exists, because it logs several times successful.
cheffing
Participant
  • Participant
  • Sep 18, 2019 8:38 PM UTC
I found a workaround: Delete the logger in the called wsp and log by python-logger in its startup-srcript. But the problem still exists .. 8-(
