Error running translation: Unknown FME Geometry 'fme_voxel_grid' specified
  • Oct 12, 2026 8:03 AM UTC
  • 7 replies
  • 171 views
hrinn
Forum|alt.badge.img+5
We have installed FME 2026.3 on both Desktop and Flow. However, it looks like there is a bug in FME 2026.3. No matter what I do in a workbench, I get the same error message. If I open a blank workspace and drop in a random file, I already get the following error message during the initial file read:
Error running translation: Unknown FME Geometry 'fme_voxel_grid' specified. A fatal error occurred during translation. FME Daemon is shutting down
Workspace generation failed.
Best answer by hrinn
Thanks, The solution was to uninstall it and install it in a different directory C:\Program Files\FME2026 instead of C:\Program Files\FME. Probably some files with voxel_grid configuration that was not deleted when overwriting the installation
crutledge
Forum|alt.badge.img+55
  • Oct 12, 2026 10:36 PM UTC
Have you tried turning it off again?
....reinstall? Another machine?
itsmatt
Forum|alt.badge.img+48
  • Oct 13, 2026 2:26 AM UTC
Looks like it was deprecated in 2026.1/2025.2
https://support.safe.com/hc/en-us/articles/25407729702029-FME-Deprecations
Deprecated Feature Year Deprecated Recommended Action / Replacement
Voxel Geometry (fme_voxel_grid) 2026.1 None
Qubicle Binary Voxel File (QB) Format 2025.2 None
hrinn
  • Oct 13, 2026 8:52 AM UTC
crutledge
  • Oct 15, 2026 3:52 PM UTC
Classic IT solution. Turn it off and turn it on again! 🤣 I ran into something very similar the first time I tried to manage multiple installs of FME for version control. Glad it is working for you now!
edvdl
  • Oct 30, 2026 10:00 AM UTC
Interesting solution , install in a different directory. On our server it is already  installed in a folder FME2026, but we get this exact error too. With FME2024 the workbench  runs allright, but with 2026.3 version it does not!
hrinn
  • Oct 30, 2026 10:48 AM UTC
To clarify. My solution was for desktop. We did not have that problem with the Flow installation.
edvdl
  • Oct 30, 2026 1:07 PM UTC
My situation is also for FME Form, but it is installed on a server ;)
