Error on conversion of CityGML file to IMX
  • Feb 13, 2018 3:08 PM UTC
  • 115 views
When I use FME Quick Translator to convert CityGML file to IMX, I get this error. How can I fix it?
Best answer by nathanatsafe
Hi @alialaghbandrad, thanks for posting your question!
It sounds like there is some issue regarding your log file or its location. Do you have permissions to write to the directory you've set? Does the directory already exist? Will the translation run if you choose to write to another directory?
Hope this helps troubleshoot the issue.
Best,
Nathan
nathanatsafe
Forum|alt.badge.img+9
  • Feb 15, 2018 8:38 PM UTC
Best,
Nathan
It is fixed now.
I should have only chosen a place for log and imx files.
