error ISO1030-21 on reading IFC format in FME Data Inspector
  • Dec 30, 2024 6:36 AM UTC
  • 0 replies
  • 40 views
kalok135791
BANNED
The IFC data was exported using ArcGIS Pro. After importing it into FME Data Inspector, the following errors occurred:
  1. ISO10303-21: Skipping instance #50: Instance  is not syntactically valid
  2. An error has occurred. Check the logfile above for details
  3. Failed to specify the feature index as constraints on the reader
Could anyone please help with this? Thank you!
