Entity problems in Writer of a dwg file under FME 2018
  • Apr 14, 2020 12:59 PM UTC
  • 0 replies
  • 45 views
Hello, I am making corrections on dwg files, I currently have a problem in my output file (in Writer) it created several entities () as in the attached photos instead of a single entity () .
Do you have a solution to prevent the entities of this layer from multiplying for no reason? the entities added are of the same layer: EP_PRO_SUPPORT
The problem apparently comes from the creation of the file in Writer because in the previous step, at the level of the Transformers FeatureTypeFilter I have no problem on the entities of this layer in Data Inspector.
In addition I have the same number of entities in Writer and Reader on this layer so there should not be any problems with these new entities which do not come out of nowhere.
Here is my FME file to better understand:
thank you in advance
