Edit encoded format attributes and write in output
  • Sep 13, 2017 4:02 AM UTC
  • 42 views
I am using FME13, trying to modify a .dwg file.
The original file has lots of information written in format attributes and there are also some encoded utf-16 format attributes. I am able to expose them and transform or modify the strings but I cannot get any in the writer output file. I don't want new extra attributes so renaming the format attributes to something else wouldn't work. Is it possible to edit encoded format attributes and write them out?
Thanks!
mygis
Forum|alt.badge.img+14
  • Sep 13, 2017 4:20 AM UTC
Have you looked into the AttributeEncoder? Not sure if it is available in FME 2013 though.
  • Sep 13, 2017 4:21 AM UTC
No AttributeEncoder isn't available for FME13..
