EBC format database file EBDIC
  • Jul 9, 2021 5:01 PM UTC
  • 5 replies
  • 270 views
gisbradokla
Forum|alt.badge.img+27
I am interested in a way to translate these database (Tape) files into a usable format. Anybody have experience?
Extended Binary Coded Decimal Interchange Code (EBCDIC) is an 8-bit character encoding used mainly on IBM mainframe and IBM midrange computer operating systems.
EBC format description
Category: Document files
Application: -
Mime-type: application/octet-stream
Best answer by david_r
EBCDIC is just the character encoding, not the actual format. As long as you can read the format itself, FME should be able to handle the EBCDIC (also called ibm037) character encoding, e.g. using the AttributeEncoder.
An alternative would be to use Python in FME and a dedicated module, e.g. https://pypi.org/project/ebcdic/
You cold try to start by reading the file using the Text File reader with the encoding set to EBCDIC, e.g.ebcdicThe result will probably still have to be interpreted in some way:
105 0001000100000000000000WILDCAT                         0001451612132232571972100199999000000000100000200000990100000000000000002000000000000000000000000000000000
  • Jul 12, 2021 6:37 AM UTC
gisbradokla
  • Jul 12, 2021 12:00 PM UTC
Thank you that is helpful. I’ll try it.
gisbradokla
  • Jul 12, 2021 1:13 PM UTC
hmm, apparently i do not have that encoding as an option.CharacterEncoding
  • Jul 12, 2021 2:53 PM UTC
Make sure you have a recent version of FME. You can download and install several versions of FME in parallel, as long as you install them into different folders. This can be very helpful for e.g. testing purposes.
gisbradokla
  • Jul 23, 2021 2:32 PM UTC
I do have the latest version of fme 2021. but do not have those options on the character encoding. do i have to make a specific language selection when installing?
