DXF written through FME can not open proper in ArcGIS
  • Apr 26, 2017 10:07 AM UTC
  • 5 replies
  • 82 views
Hello people, i splitted one DXF-File into 4 separeted DXF-Files. One of them i tried to open in ArcGIS, but can not see the features there. Somehow DXF-Files, which were written through FME, could be read only in FME Viewer, but not in ArcGIS. Do you have any ideas, how can i fix it? I tried already all possible format of DXF in FME to write, but still does not work.
(the main DXF-File can be open and the features could be seen in ArcGIS as well)
gio
Forum|alt.badge.img+15
  • Apr 26, 2017 10:40 AM UTC
I would check the offending file.
I have no problems with dxf files created trough fme opening in Arcmap.
  • Apr 26, 2017 2:40 PM UTC
Hey, i found the Problem: in DXF-Writer i have chosen wrong AutoCAD Version Release 2013! As i changed it to Release 2000 or 2007, it created DXF opening in ArcGIS.
gio
  • Apr 26, 2017 3:31 PM UTC
You have an older Arcgis installation then?
10.4 reads 2013 as well.
  • Apr 26, 2017 4:14 PM UTC
Yes, u are right. i have ArcGIS 10.0
  • Jun 22, 2017 8:57 AM UTC
solved, it was Settings of the dxf viewer
