DWGstyler giving different colors to different blocks. But in CAD all the blocks have the same color in red.
  • Nov 30, 2020 11:03 AM UTC
  • 138 views
I have a problem where I use DWGstyler to assign different colors to different blocks, but when I open the file in CAD, all these blocks have the same color in red. I am new to FME and hope someone can help me with this problem. Thanks in advance!
2020-11-30 11_57_47-Autodesk Civil 3D 2019 - [test20201130.dwg]2020-11-30 11_56_27-DWGStyler Parameters
nielsgerrits
Forum|alt.badge.img+67
What is the color of the block in the template? I think it just copies the source object from the template to the new file, you probably can't change the color of the block.
  • Nov 30, 2020 11:20 AM UTC
Hi, thanks for answering. I didn't use any template for creating the CAD file.
deanhowell
Forum|alt.badge.img+24
  • Dec 1, 2020 2:18 AM UTC
Can you share a drawing and the workbench so we can what is happening?
  • Dec 1, 2020 7:37 AM UTC
Hi, first I created vertexes and than give different buffer values to bufferer different vertexes. I checked a little bit, it seems that the combination of bufferer and extrusion made it problematic for the color in CAD. If I only use extrusion then I don't have the problem of seeing all the colors i defined. 2020-12-01 08_32_11-_XLSXR → ACAD (O__STH_294842_B_=Arbetsarea=_Chunling_FME Geobim_KBH_snabb lösnin
