DWG to SHP and expose attribute
  • May 1, 2018 3:06 PM UTC
  • 68 views
chris_m
Participant
I am looking to convert a CAD layer to a point shapfile. Below is the data in inspector the highlighted field are the Value I need to capture in my new Shapefile.
erik_jan
Forum|alt.badge.img+26
  • May 1, 2018 3:11 PM UTC
The main issue is most likely the settings on the DWG reader.
Make sure you have the "Attribute Schema" option on the top selected.
That will expose the NUMBER attribute.
danilo_fme
Forum|alt.badge.img+58
  • May 1, 2018 3:13 PM UTC
Nice @erik_jan
