DWG Scale Bar missing units
  • Mar 1, 2020 11:39 PM UTC
  • 165 views
deanhowell
Forum|alt.badge.img+24
We have a DWG that has a number of scale bars shown in paperspace. In the DWG the units are visible
But when it is brought into FME the units are missing.
My guess is that the units are dynamically generated in the DWG based on the viewport scale and as such are not really annotation but some attribute / tag associated with the line.
Is there a way for FME to find the values so they can then be used to output to PDF.
Update 1:
Here is a a sample DWG with the issue included.
Update 2:
What I have discovered is the scale bar is a 'block' and the text is a tag associated with the block.
Is there a way to convert the 'tag' to text in FME?
Best answer by deanhowell
Thanks @nataliewlock your article helped me get the solution I needed :)
https://knowledge.safe.com/articles/59335/autocad-dwg-block-attribute-extraction.html
nielsgerrits
Forum|alt.badge.img+67
@deanhowell if you attach an example dwg with the scalebar it's easier for people to reproduce your issue. And more likely to get a quicker response.
deanhowell
  • Mar 2, 2020 10:37 PM UTC
Thanks @nielsgerrits, I have uploaded a sample drawing so people can see the issue.
deanhowell
  • Mar 4, 2020 2:54 AM UTC
