dwg conversion
  • Aug 3, 2019 7:44 AM UTC
  • 5 replies
  • 99 views
kathir
I Have a dwg file. I need split that into multiple dwg based on the used autocad layer.
pratap
Forum|alt.badge.img+12
  • Aug 3, 2019 9:44 AM UTC
use Fanout option in writer. Use the attribute autocad_layer in format attributes of DWG reader
kathir
  • Sep 27, 2019 9:53 AM UTC
hi thanks for the reply. but the output data stored only file format. its not take dwg format automatically
Forum|alt.badge.img+54
  • Sep 27, 2019 9:59 AM UTC
If you create a new attribute by joining the autocad_layer with .dwg and fanout on that the output should be as you require
kathir
  • Sep 27, 2019 11:47 AM UTC
sorry. i cant understand what you told.can you send any example
jovitaatsafe
Forum|alt.badge.img+11
Hi @kathir,
There are some examples in the documentation for Setting Feature Type Fanouts, and a downloadable workspace template example in our Fanout article. Hope that helps!
