Duplicate features into another feature class?
cwarren
( GDB to GDB )
I would like read the features LINE_A and copy their geometry and attributes and insert those into LINE_B feature class, then run it through my transformers before writing. Is there a way to do this?
Example
LINE_A has 2 features. Before my workspace is ran I would like to take those 2 features and insert them into the LINE_B feature class with any attributes that match the schema of both features, then run the workspace with those new features added.
So I'm keeping the 2 instances of LINE_A and just copying them into LINE_B feature class... then running those 2 new features through the workspace.
I looked into the workspace runner, but wasn't quite sure.
Best answer by kam
Hi @madwarren,
Why don't you just read LINE_A and push it through the transformers as required and then write to a new feature class called LINE_B? That way it's done in one workspace.
Regards,
pratap
Forum|alt.badge.img+11
  • July 12, 2016
Option 1:
Yes, you can write 2 work spaces ( one to copy and other to translation as required) and use workspacerunner in 3rd script and run both the scripts one by one.
Option 2:
If you are using latest version of FME then have a look at Feature writer...
http://docs.safe.com/fme/2016.1/html/FME_Desktop_D...
Later (in the same work space) you can add the output as reader and use featuremerger such that flow should continue after writing of step 1.
Hope it is clear
  • July 12, 2016
Hi @madwarren,
Regards,
gio
Forum|alt.badge.img+15
  • July 12, 2016
I agre with Kam. Writing, workspacecalling or creating a merged featureclass is unnescessary.
Just read both classes and push trough the workspace. Dump redundant attributes if you must.
cwarren
kam wrote:
Hi @madwarren,
Regards,
Thanks @kam , I seem to over complicate what I intend to do sometimes.
cwarren
@gio thanks!
cwarren
pratap wrote:
Option 1:
Option 2:
Hope it is clear
@pratap
thanks!
