Does FME support the new ArcGIS Online data types
  • January 28, 2025
  • 6 replies
  • 87 views
Forum|alt.badge.img+49
Quick and easy question I hope: does FME 2024.2 support the new ArcGIS Online data types (Date Only, Time Only, Timestap Offset and Big Integer) as described here: https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/time-is-on-your-side-with-new-field-types-in-arcgis-online/
Best answer by nielsgerrits
Yes on the gdb writer.
No for the API writer.
Checked using 2024.2.1.0 (20241202 - Build 24801 - WIN64)
nielsgerrits
Forum|alt.badge.img+54
  • January 28, 2025
jobvdnoort
Forum|alt.badge.img+10
  • January 29, 2025
I’ve used the time only and date only fields in FME 2023.2 as well.
Just make sure the arcgis running on your PC complies.
  • January 29, 2025
Thanks ​@nielsgerrits and ​@jobvdnoort. Sounds like it’ll also differ per (writer) format.
kimo
  • January 29, 2025
Don’t use them! It will only be the start of your troubles. Relates cannot use BigInteger keys. Many other Esri tools will fail with these new datatypes.
  • January 30, 2025
That's good to know, this is a question coming from one of our clients, I'll pass this on.
jobvdnoort
  • January 30, 2025
haha I had a similar question from a client.
End result:
the date and time fields types ended up as char….. 🤦
(and a seperate datetime field)
