Does FME support the new ArcGIS Online data types
  • Jan 28, 2025 2:59 PM UTC
  • 6 replies
  • 201 views
Forum|alt.badge.img+63
Quick and easy question I hope: does FME 2024.2 support the new ArcGIS Online data types (Date Only, Time Only, Timestap Offset and Big Integer) as described here: https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/time-is-on-your-side-with-new-field-types-in-arcgis-online/
Best answer by nielsgerrits
Yes on the gdb writer.
No for the API writer.
Checked using 2024.2.1.0 (20241202 - Build 24801 - WIN64)
nielsgerrits
Forum|alt.badge.img+67
jobvdnoort
Forum|alt.badge.img+14
  • Jan 29, 2025 8:17 AM UTC
I’ve used the time only and date only fields in FME 2023.2 as well.
Just make sure the arcgis running on your PC complies.
Thanks ​@nielsgerrits and ​@jobvdnoort. Sounds like it’ll also differ per (writer) format.
kimo
Forum|alt.badge.img+10
  • Jan 29, 2025 10:42 PM UTC
Don’t use them! It will only be the start of your troubles. Relates cannot use BigInteger keys. Many other Esri tools will fail with these new datatypes.
That's good to know, this is a question coming from one of our clients, I'll pass this on.
jobvdnoort
  • Jan 30, 2025 1:18 PM UTC
haha I had a similar question from a client.
End result:
the date and time fields types ended up as char….. 🤦
(and a seperate datetime field)
